sternzy »
https://forums.nicoclub.com/sternzy-u153455.html
Thu Aug 19, 2010 8:08 pm
After researching for a week or so I haven't really found a definitive answer for the p0171 code (lean bank 1).
The actual symptoms of this code are presently rough cold starting. Throttle response seems excellent once it is warmed up, though the idle can be a little rough it is nothing that say a novice would probably even notice.
After looking the car over this past week and learning all the functions of my code scanner and such, I have noticed a few things...
Cat, and o2 sensor monitors are n/a even after an hour of driving. Now I'm guessing the cat monitor being n/a could be directly related to the o2 monitor not being available.
After reviewing the live data on my Actron 9180 I have found that at a flat idle my o2 sensors look like this, through the entire 35 frames or so:
o2s11 - 0.000
o2s12 - 0.240
o2s21 - 0.000
o2s22 - 0.250
11 and 21 do fluctuate when the idle is revved but still lower then spec I believe. Am I understanding this correct in that i have two bad sensors, and two others that are on their way out? It seems to me that an o2 sensor should not read a flat 0.0 even at idle. Out of 34 snap-shots at flat idle those 0.0 numbers did not change at all.
I will do a 2k RPM snapshot tomorrow. I think I have a good idea of what they should be reading now after reading a Nissan PDF. In the mean time I am am curious what you all think about these numbers.
I have cleaned the MAF, and for the data recording it averaged 1.8 - 2.0 throughout the recording at idle. I also cleaned the air filter, and will be getting a new one, along with a new fuel filter tomorrow before I get into buying new o2 sensors.
Two other things I should mention:
First, the air duct on this car is a mess. The air-box containing the filter is fine, other then the dry rotted seal that attaches it to the scoop. Is this air-duct a priority to repair? The entire rest of the engine compartment looks immaculate, but for some reason this intake scoop is a mess.
Second, when reeving the car from under the hood I can hear a suction noise coming from somewhere around the bank one side, though as hard as I tried I couldn't pinpoint where it was coming from. For all I know this could be a normal noise the coming from the intake as more air-flow is being sucked into the system. I did read about a bad intake gasket on these cars though so i thought I would mention it, where I am having a lean condition.
Thank you in advance for any help!
P.S. Is it possible to still buy after market MAF and o2 sensors which are OEM and do not require a dealer ECU reprogram? If so what differentiates the two separate models? Maybe an "a" or a "b" in the part #?
