VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Apr 20, 2022 4:40 pm
Yep, that looks pretty okay. That means you either have an actual lean condition on bank1 only, or something is fooling the sensor. Has to be something pretty odd, there aren't too many things I can think of to cause that without throwing a bunch of codes. Small upstream exhaust leak, low supply voltage to injectors on one bank, obstructed fuel rail on one bank, stuck intake runner on one side. Plugged cats can cause weird stuff, rich or lean kind of depends on whether it's plugging up or coming apart. But that usually throws codes. You can test that by seeing if the rear O2's respond the same on both banks when you add propane. That's all I can think of. I'll post back if anything else occurs to me.
