p0161 code 2001.5 pathy
yngw13
Car: 2001 Nissan Pathfinder SE
driving smoothly since I got it....today the SES went on...pulled this code...
But the weird thing i have 2 of them the other is "pending" (same code) as I read it from the obd scanner
what sensor is this and is this an easy fix? TNX!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Replace the driver's side post-cat (downstream) oxygen sensor with this Bosch direct-fit sensor from Advance Auto Parts. Bosch is the manufacturer for the OEM sensor. Order online and use discount code VISA and pick-up in store to get the sensor for $50 before tax. You'll need a 22mm or 7/8" oxygen sensor socket for replacement.
yngw13
thanks town!
I'll get on it asap :)
also...is this under the driver side? I just need an approx idea....thanks again
Towncivilian
Yes, driver's side. It's very easy to spot the sensor. See tips on replacing the O2 sensor here.
