P0158 O2 Sensor Location
QBOY
Car: 1999 Infiniti Q45t
I have the following DTC codes P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)P0159 02 Circuit Slow Response (Bank 2 Sensor 2)P0158 02 Circuit High Voltage (Bank 2 Sensor 2)
Now P0158 was the first to come on. I was trying to research it and find out which sensor it was - I think I found out that it was one of the Rear sensors but what side is it - Drivers or Passenger.
Could one of these coded be causing the other or are both the Knock sensor and the O2 sensors bad?
Please - Any information would be greatly appreciated!
1999 Infiniti Q45t - 103K
Modified by QBOY at 2:12 PM 8/3/2006
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
You might benefit from replacing all of the O2 sensors with 103K miles on the car. Similarly, replace both knock sensors with a new harness. sparkplugs.com has the O2 sensors.
Good luck!
