mikenearmilwaukee »
https://forums.nicoclub.com/mikenearmilwaukee-u85780.html
Tue Jan 15, 2008 3:36 pm
Hello, Im not that new to this forum. However, I seldom post unless I can not find an answer already posted. Let me take a second to thank everyone to whom Ive been a somewhat wittless voyeur. As you may have guessed by the title of this topic, I have got the CEL on with the only code of P0156. Not to big of deal right? Just replace the o2 sensor and off we go... Well, not so much. I have a 97 J30. Shes fixing to get her emissions test by the end of February. Ive been trying to fix this code for sometime now. I have of course replaced the sensor on the passenger side on the cat. I have checked the wiring that leads out of the bottom of the car. Is that harness slightly above that sensor for the back two sensors? I cant tell. ? I wiggled them around anyway to hopefully correct a poor connection. However, the scan tool says the heaters on the sensors pass. So, only one of two wires could loose, so I doubt thats the problem anyway. At any rate, what else can cause that code to be set? Is it purely for the sensor itself, or could the sensor be saying there is trouble in xyz system, there by setting the code. If so, what are a few of the systems I can check? There is a small leak somewhere in the heat shield area near the cat, you can hear/feel exhaust coming from it. Also, I replaced my spark plugs with universals. Could that somehow effect it? I plan to replace them with the NKG ones that Ive read so much about here. I did it before I knew of this forum. I just have to wait until it gets warmer here. I can only lay on the ground to fix this car as much as I have to - to get it to pass emissions. Will I pass emissions when not all the systems have passed the computers test, ie, erased code, drove for sometime, then went to get the test... the o2 sensor always seems the last to be tested for some reason - no matter the drive routines I take. Ok, now Im starting to babble and have already asked to many questions. Thank you in advance for any ideas you may have, all that is google has turned up a complete zero for any ideas on this code for this, or similar vehicles. You will be doing myself, and all others to follow a great service. Thank you again.
