P0140 O2 Sensor Circuit No Activity Detected!!! Easy fix??
longhornsqx4
Car: 2001 Nissan Pathfinder 3.5L VQ35DE
EDIT: SHE finally threw a codeP0300 Random/Multiple Cylinder Misfire Detected
Modified by longhornsqx4 at 4:27 PM 11/27/2009
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
The below is for a Pathfinder, but the picture provided is for a 2001 QX4
Nissan Technical Service Bulletin #NTB02-006 addresses the following codes for 2001 Pathfinders:
^ P0138^ P0139^ P0140^ P0158^ P0159^ P0160
The bulletin states that if you have any of the codes, replace the incident O2 sensor. If you have codes P0138, P0139 or P0140, replace the rear RH O2 sensor with the following part, based on pro date:
Built up to 8/1/00: P/N: 226A0-4W001Built on 8/2/00 or later: P/N: 226A0-4W010
And I am pretty sure I've circled the correct one below...
longhornsqx4
Passenger side front one...
And you think I most likely just need a new one??
Ron Burgundy
Thats the recommendation...
I'm pretty sure i've heard people cleaning them by soaking them in gasoline but thats up to you.
OR what you can try is clearing the code and seeing if it comes back. A lot of the time severe temperature changes can throw codes for this.
That is actually the passenger side rear. Rear O2 sensors actually have no effect on drivability they just monitor emissions post-carb (or something along those lines). So if you're not looking to spend money, you can just....do nothing.
I currently have two codes for rear O2 sensors and I do plan on taking care of them, its just not at the top of my list. If the light bothers you, clear the code every time and just check regularly.
Hope this helps!
longhornsqx4
Well the car is defientely running like HORRIBLE, so something is wrong
Thats the only code it threw though
longhornsqx4
I disconnected the battery again and let it sit overnight, connected it this morning, startup was a little rough and had to give it some gas to keep it alive for a second, then it levlled out @ 1200rpm (its cold as hell), idled DECENT for a few minutes without stalling, but still sounded rough / small miss
No codes popped up right away, but I didnt go anywhere and drive it any place, had knowwhere to go lol
Ron Burgundy
When is the last time you changed your fuel filter?
longhornsqx4
Last year
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
The '01s have a mondo fuel filter. FSM does not specify a change interval.And a dirty fuel filter will affect high revs first, then medium revs, and onlyidle if it's REALLY REALLY dirty. So I don't think it's fuel filter.
Any chance you have multiple codes and are only seeing the first one?
longhornsqx4
Well thats the only one thats popped up so far, I dont drive much though
longhornsqx4
SHE THREW A CODE!!!
When I started it up I had the scanner connected, and P0300 came up
It sounded like it was on a few less cylinders, as the exhaust note sounded like it was pulsing quite a bit, car had no power trying to elave the driveway, then like 2 minutes going down my road @ 10mph it cleared up and the car ran much better, aside from the slightly struggling idle dipping down into the 400rpm range....
ANy ideas??
Chuck Tribolet
'87 Chevy Corvette
What happened the next time you fired it up cold? After a long battery disconnect, the ECU forgets the fine tuning for your engine and has to relearn it.
longhornsqx4
Ran like poop, the car will still die out on idle after completely warmed up aswell
cminor9
Car: 2000 Nissan Pathfinder LE
so did you ever figure this out? I think I am having a similar problem.
