P0133 code slow response error
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Ok I got the SES light on in my M Sunday had AutoZone pull the code P0133 AF sensor bank1 passenger side took it to my mechanic and he side its a soft error
not hard so I should clear the code if it comes back then replace the sensor this all happened after running 87 shell gas in my car I never run that gas only 93
the car is running mint should I just replace it or wait and see it the ses comes back on thoughts ?
Ilya
I'd definitely wait and see. Also, IIRC, this may be related to the gas cap not being seated properly or something? I'd reset it, fill it with at least 89/91, and make sure cap is clean.
lovemycarM35
Nebula Gray
19" wheels
12.3 inch display
Navigation
Thanks for the replay IlyaKol I'll give that a shot first, maybe I should replace the gas cap
Larz
Car: 2019 Q70-L RWD
I would also wait instead of just replacing something that is probably working correctly (the code did not indicate a failure of the sensor). These cars have very finicky and quite complicated computers and possibly changing to a lower octane sent a bit of confusion through the comp. Making sure the gas cap is screwed on properly and just for 1 click (as Ilya suggested) is also a great idea. Using 93 octane as you usually do, is probably best for the car as well.
Just as a side note, the difference between the cost of 87 and 93 octane is really not that significant when you work out the math. Let's say you burn 5 - 6 tanks of fuel each month, and the added cost of 93 octane is 15 cents / gallon. That works out to about $15 - $20 per month. Although that is not huge, it is still $20 per month. You can cancel out that expense quite easily by taking a home lunch to work 1 day each week, or washing your car in the driveway instead of paying for a car wash, etc.
