Plugs were on the right spots. All hoses and harnesses were connected.
I wasnt able to get an accurate reading from the harness.
However, I wonder if I installed the throttle position sensor correctly after I removed it.
There is the gold bar that the TPS goes over. That gold bar goes to the valve opening and closing for throttle. On the TPS there is a spring like mechanism. Does that spring go in front/right of the gold bar or does it go behind the gold bar? To get it in front you kind of have to put it in crooked and turn it so the screw holes line up. Doing it this way my idle RPM was roughly 13-1500. Before that it was at about 5-700.
The spring in the TPS only moves one way. It appears if you just drop it in and bolt it in place the valve position doesnt move that sensor spring.
Here is a quick paint drawing I did to try and display what I was talking about.
