P0104 - Mass or Volume Air Flow Circuit Intermittent
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
newbone
Car: Infiniti QX56
What could cause this problem, would an aftermarket filter be enough or is it the MAF sensor?
PapaSmurf2k3
Site Admin
If you run an oiled filter, its possible it was over-oiled and coated the MAF sensor with a film, causing inconsistent readings. I'd pull the filter and inspect the area/tubing after it to see if there is any film on it. If so, you'll need to clean the MAF.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
