P0011 and P0021 Codes
brian1969
Car: 2002 Maxima SE 6 Speed
Hey Guys,
Was driving in my lovely Maxima yesterday when the check engine light came on... Got it checked at Autozone two codes P0011 Intake Valve Timing Control Circut Failure Bank 1 and 0021 for Bank 2. Car runs fine....
Have gotten bent over by the dealership one to many times. Wondering if anyone has experienced this and what the fix was. Also, I have tried to clear the code with the famous "gas pedal pump" with no sucess.
Thanks in advance,
Brian
alukfan
Car: Infiniti 2002 I35
Hello,
I am a member of another Infiniti forum. I ask this question not only in this forum but in the another one, too. The answer I got, in the other forum was the following:
"Yes, it usually happens with the oil gets to dirty. Changing the oil and filter, and resetting the light usually takes care of the problem. In rare occasions the sensor is damage and it needs to be replaced to repair the problem."
Now this was on my 2002 I35 Infiniti, which is the same engine as your Maxium 2002.
I have reset my light four times over the last six to seven months with my handheld reader. I have changed my oil once since this happen and it stayed off for a longtime, after erasing it. So....I don't know, you should get a reader, they are handy.You may want to buy one. Autozone under $80.00, mine was $69.99. It will read the code and let you erase it. Anyway, I am not saying that this is the answer, but it is the only one I have gotten from the forum's. The guy who answered was an Expert Infiniti Helper. look under the Infinifihelp.com. My post is on 02-02-2008.
Good Luck!
Alukfan
welcome2
I would try to replace the Crankshaft or Camshaft sensors. Next, I would also check to see if the engine has lost compression, if it did then I would replace the head gaskets.
Modified by welcome2 at 11:13 AM 12/10/2008
