P/S pump replacement in hardbody with V6
TrimDude
Car: 2009 Nissan Sentra 2.0
1986.5 Nissan Hardbody SE
1995 Nissan Pathfinder XE
2017 Nissan Quest SV
Hey all,
I am looking to replace the power steering pump in my 86.5 HB 3.0 because it leaks like mad and had weird spots of non power assisting while I am driving. Any tips, tricks, special tools/pullers I need? And whats the proper bleeding technique for this pump.
Thanks !!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Shouldn't need any fancy tools. To bleed you need to fill the system then with the engine running turn the wheels lock to lock a few times.
TrimDude
Thanks for the info, just makin sure. Now to talk myself into doing this....
Rev_D21
Eh, you'll do fine. Let us know how it turns out.
TrimDude
Will do, just getting info at this point. The truck is still at my Moms house being used as a work truck in CA. I just had a new OEM clutch put in. I need to go rescue her soon!!!
