frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Tue Sep 14, 2004 5:43 am
I've had some problems with my powersteering. Turns out it isn't the pump. My pressure line gets really hard and vibrates excessively when I turn the car on. (after I correctly bleed and blah blah blah, please DO NOT tell me to bleed it again) The problem with the hardness and vibrating is that the line should be softer and not as firm. The other people with 240s in the area all have soft lines when the car is on as well. Sooo, my new assumption is that there is air in my rack or other part ofthe system. Does anyone have a way of bleeding the rack or system that isn't the standard "take the wheels off the ground fill the pump, turn the wheel, fill again etc?" because that obviously isn't the issue anymore.
