Highway Q45 »
https://forums.nicoclub.com/highway-q45-u1500.html
Mon Jan 13, 2003 5:14 am
I had a major P/S hose blowout about a week ago and nearly a fire due to the fluid blowing directly onto the exhuast, downpipes, and cat. It was a short HP hose running between the HICAS Control Valve? towards the front (banjo-to-straight fitting). I noticed that the low pressure reservoir-to-pump hose has a heat shield type wrap even though it isn't that close to the exhuast. The two hoses to the HICAS unit are within 2" of the exhaust and are not wrapped at all. This was a very difficult hose to replace, and least for me. P/S fluid has been flushed (dealer) about every two years and levels were kept up. Is failure of these hoses in this area common due to overheating? Would a similar wrap to hoses parallel to the exhaust help prevent this in the future? Anyone?TIA
