Are you having trouble with your oil temperatures? Most 240's i've seen don't really need one, except for all out race, curve hugging monsters. If you have high temp. oil, i'd look for any failures rather than a patch.Dookie wrote:Right now Im working on a P/S cooler for the s13. Im using these oil/fluid radiators I found at my friends house. The only PIA I have is mounting them. I cut the brackets off of the resonator box and Ill be mounting it in its place. Im using epoxy to glue the brackets to the cooler. Will this work or am I just wasting my time? The epoxy says not to use in over 200 degree F conditions.
