P R N D light is off 90% of the time...
Hugo L.
Car: 2008 Nissan Rogue SL
2005 Subaru Legacy GT wagon
1999 BMW M3 'vert
... but sometimes ights up randomly, sometimes after I give it a whack.
Any ideas or solution?
DTASFAB
I had the same problem with a 1986 Camry. Sometimes the D would light up, sometimes not. When the R would go out on the dash, the actual reverse lights wouldn't turn on at the back of the car, but I could still move in reverse normally.
Sometimes I could get the lights to turn on or off by jiggling the gear shift. Replacing the neutral safety switch fixed it. No idea if the Rogue is configured and equipped similarly.
sprocket
There is a position lamp that lights up the shifter position plate, sounds like a loose connection to the lamp, or the lamp itself?
Return to “Rogue Forum”
