P 0160 Code
slinger5150
Car: 1999 Infiniti Q45t
Threw a P 0160 code today. Shop manual says right rear O2 sensor. Where's the best/cheapest place to get one from? I'll replace it myself.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.sparkplugs .com (call to verify as website often lists wrong part number) or http://www.infinitipartsusa.com
Best done in pairs so the duty cycle matches the other one.
Modified by maxnix at 8:52 AM 2/5/2007
slinger5150
When you say pairs are we talking both front and rear right, or both rear sensors?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Pairs in same position left and right for operational bank symmetry.
slinger5150
Thanks!
99q45t_vl
Car: Grey 2014 QX60
Dark Green 99 Q45t - gone
The FSM says 'Under normal conditions the rear heated oxygen sensor is not used for engine control operation'. It is there to satisfy the treehuggers and you will waste money replacing it.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Not true! Rear sensors are used for final trim.
Q45tech
The problem is we don't know WHAT a failed secondary O2 does besides flag a code ...............how the ecu reacts to a signal that the cat has failed.
It {OBD2] just assumes the secondary has failed not the CAT or does it do something protective just in case?
The reason you replace O2 is to turn the light off so you DON"T MISS SOMETHING MAJOR.
There are 300 things that can turn the MIL light on some minor some very major and engine life threatening!
