dcat151 »
https://forums.nicoclub.com/dcat151-u78709.html
Wed Oct 17, 2007 3:23 am
Hey everyone: I just registered here (and just found the site yesterday). I purchased a 1997 J30 with 68K miles on it this weekend. Unfortunately, I already have a question.
I was driving it yesterday and the check engine light came on. I went to Advance Auto Parts and had them pull the code for me. The code was P0150: oxygen circuit malfunction bank 2, sensor 1. I looked the code up on this site and confirmed it was an oxygen sensor. I've looked at a couple of the threads regarding oxygen sensors and it appears to be a DYI project. My question is: which oxygen sensor is bank 2, sensor 1? From reading the threads here I understand that there are four sensors. I was told by the Advance employee that it was the downstream sensor, or the one after the cat, on the driver's side.
Assuming that I can change out the oxygen sensor, is there a way to reset the check engine light? (I know on my S2000 I just pull the ECU fuse, but I don't know if the procedure is the same on the J30.)
Finally, I read in the owner's manual that the J30 uses 91 octane AKI gas; the former owner mentioned using 89 octane AKI gas, so I assume this is what he used. I have not noticed any problems with the car (knocking, etc.) (aside from the oxygen sensor), but is this a serious problem?
Sorry to start off with so many questions. I appreciate any help anyone can give me.
Thanks.
