redincali »
https://forums.nicoclub.com/redincali-u102928.html
Fri Dec 10, 2010 6:12 pm
Ok, so I bought a kia for my girl to drive. Its a 2001 kia sephia ls. I changed both o2 sensors the other day. They're universal so they had to be wired. Now after the car is warmed up and turned off for a few minutes, I start it back up and a few minutes later my check engine light came on. So today I purchased an OBD2 reader and it gives me two error codes, one for each o2 sensor heater.
Theres 4 wires, white/white/black/grey which are heater/heater/signal/ground. Since my error is with the heater could that mean my heater wires are just connected backwards or does that even make a difference? I have been searching for the harness layout, no luck, but during my search I had seen one harness that had their heater wires labled "heater/heater(ground)"
Im at work and will be tomorrow but its an adult shop so I have free time to mess with it here. I should be able to test the plug itself for voltage to determine each one, right? So if anyone has any useful information, it would be much appreciated. Thanks in advance.
