OxyELITE Pro use questions
joe603
Car: 2014 Durango R/T
I have a few coworkers that use OxyELITE Pro and seem to have good results with it. Just curious to see if any of you guys have tried it and what your results were.
Thanks!
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
I am just starting it, and believe me, it does give you a ton more energy. I haven't been taking it long enough to notice weight loss with it, but it'll give you the energy you need to burn calories. Just make sure you stay hydrated, because it's a thermogenic, which means it will make you warmer than normal, making you sweat more.
ADDirishboy
Car: 2008 Nissan Titan Pro4x
Ace2cool wrote:I am just starting it, and believe me, it does give you a ton more energy. I haven't been taking it long enough to notice weight loss with it, but it'll give you the energy you need to burn calories. Just make sure you stay hydrated, because it's a thermogenic, which means it will make you warmer than normal, making you sweat more.
That sounds like something I DON'T want happening...
Dattebayo
I heard you spontaneously combust if you do too much.
RobPaulson
Car: 2013 Subaru WRX
make sure you follow the instructions, it must be done and cycles and should not be taken for too long of a time. I began using it sometime into starting crossfit with serious dieting. I did not notice much of a change beside the initial 3-5lb loss from water weight. After that, it just kind of made me really uncomfortable and schvetty. :eek:
AZ89two4Tsx
I wish they made fat gainers. :(
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
It's called McDonald's.
