Wiring harness causing my speedo not to work
95_240
Car: 1995 240sx
With the previous harness I had my speedo worked on my car. I was just trying to get a harness that cleaned up my engine bay a little bit. Big mistake.
So now my speedo doesn't work and I'm getting power to one of the wires and the other wire has continuity with pin number 53 on the ecu. The f3 plug does not have a wire going to the number 24 slot for the speedo. I'm assuming this is the reason I'm not getting signal. Where do I get the signal for this wire? This is for a RB25 series 2 into a S14.
Thanks
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Speedo goes to Lower harness goes to fusebox in engine bay, down by the headlights, over the rad, through the driver fender, and up behind the dash. That's a speed signal wire for the ecu is so the ECU knows your speed, unnecessary for the cluster.
:biggrin:
TimTurboZ
Check your fuse in your kick panel or your harness wires? your car lowered? I lost my speedo in my coupe that way until I realized the problem
95_240
Car: 1995 240sx
Thanks for the help. I'll check continuity between the sensor and the cluster to see if that helps narrow down the problem. This harness is just making everything a little more difficult because the wiring is different colors than factory wiring.
95_240
Car: 1995 240sx
Guess what. The harness is to blame again. This is the fourth thing that has been miswired so far that I have had to troubleshoot myself.
240z4u
Car: '95 Nissan 240SX
*deleted* don't want to throw them under the bus if they didn't build the harness.
95_240
Car: 1995 240sx
Nope. I'm sending it back and maybe they can fix everything this time.
