Overnight loss of tire pressure
riskNeutral
Car: M37x 2012
Hello Nico-members!
My Infiniti is experiencing an overnight loss of tire pressure in the rear passenger wheel. The pressure drops about 4-5psi overnight in just one wheel (Rear-Passenger) and the TPMS warning comes on every morning when I move the car from its overnight parking spot. I am scheduled to take it to the dealer this coming Wednesday, but I was wondering if anyone here has experienced a similar problem?
I do re-inflate the said tire every morning to a pressure of 30-32psi using an air pump. My Infiniti is a 2012 M37x leased this September and has about 3,000 miles on it. Any suggestions or pointers will be highly appreciated!!
regards
IC
Jersey City, NJ
cji4130
Car: 2006 M35x
You probably just have a nail in your tire, or it could be the weird fluctuation of weather were having here in the northeast.
myother45isalesbaer
Car: 2004 M45 Q70 awd,4.5
I live in the NE and my tires are down a few pounds just due to the dropping tempertures. Your leak is more than likely caused by a nail or other item that punctured the tire. It could also be a rim leak, valve stem leak and many other reasons. Take it to a good tire shop and have it fixed is about the only thing you can do.
Tiggaman
Car: 2012 Infiniti M37s
I had the same issue. Pressure would drop consistently any time a cold front came around. I switched to nitrogen and never experienced the issue again.
KoMikeey
Car: 2007 M45 S, Aero kit, Diamond Graphite, Uprev, Injen CAI, G37 sport vlsd differential swap, Full custom exhaust (removed secondary cats) into an x pipe through the megan exhaust.
Go nitrogen, and also, Nissan/Infiniti TPMS are known to be very sensitive. if it goes down one or 2 psi, the warning light will go on, i suggest you fill it up to 32-33 in the cold with nitrogen or warm them up and fill them up with nitrogen to 34, i had the same problem in cold. but in both my front tires.
M35SFIREMEDIC
Car: 2008 Infiniti M35S, Moonlight White, K&N Filter, Mobil 1, Michelin Primancy MXM4's.
As everyone has suggested, most likely temp drop, but check for nails. I recently had a big pressure drop of about 10psi and knew it was a nail. I check and found three in that one tire :facepalm: if you don't have a tire warranty GET ONE!! Good luck.
riskNeutral
Car: M37x 2012
Thanks. I will take it to a good tire shop for a thorough check.
FNAWSM
Car: Diamond Graphite '06 M45
Im guessing bad tire bead or a nail that you are overlooking. Hopefully not a bent/cracked rim or anything. Most likely a $20-30 fix that any local place can do. I wouldnt take it to infiniti for just that issue, unless you love paying 3x as much for the same thing. Good luck
