overnight batt drain
griffadavi
Car: 2002 q45
every morning i come outside my batt has been dead and i have to jump. i had the batt tested and its good. (practically brand new) so i have concluded its a drain. i went out and bought an Innova 3306 10 MegOhm Multimeter. i tested it out and theres seems to be a drain. i then started pulling fuses however there wasnt a drop at all. Anyone have any insight on this as im confused? is it the multimeter settings?
Skibane
Car: 2000 Q45 AE 110K
I guess the answer to your question depends on how much current drain you're measuring with your meter. If it's a few amps, you've definitely got an unwanted load somewhere in the vehicle. However, if it's just a few dozen milliamps, that's normal - and would take many weeks to completely drain the battery.
griffadavi
Car: 2002 q45
yeah its a few amps.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
You have a bad battery, dump whatever you have and buy a new higher quality one.
griffadavi
Car: 2002 q45
batt is pretty much brand new. just had it tested 2 days ago
Skibane
griffadavi wrote:i then started pulling fuses however there wasnt a drop at all.
Not all of the loads are connected to the fusebox.
Try pulling the relays in the engine compartment junction box.
Also - Do you hear any mechanical noises in the engine compartment after you shut off the engine and remove the key?
griffadavi
Car: 2002 q45
yea tried that too. wasnt sure if there was noise after shut off so i checked this a.m. neg...man im lost...
Skibane
I assume the 2002 model still has a 120 amp fuse located right at the positive battery post. You might try pulling it before measuring the current drain - It should disconnect EVERYTHING from the battery except the starter.
Also, note that the car will draw more current for a few seconds after you reconnect the battery, until some of the electronics can power down. So, be sure sure that you don't measure until after everything's had a chance to settle.
srwood11
Car: 2005 Q45 Premium Black
1997 Q45t Black
2004 I35
2004 G35
What is a normal drain rate when sitting idle? Mine is 140ma. 97Q Thanks
