extheflow »
https://forums.nicoclub.com/extheflow-u3097.html
Sun Feb 15, 2004 5:29 am
ok i have some extra stuff tapped into my tachsignal wire from the ECU. i have.1)the stock tach2)AFC II3)wideband
now with the wideband hooked up my tach signal is garbage,like it can't supply power to all these things,so i need another source.i also plan on adding an AVC-R, and a shift light.both of wich require tach signal, is there a ource inside the car that will work for the wideband and AVC-R and one in the engine bay for the shiftlight? or maybe an adapter of somekind that will allow me to use the same source i'm using now.help a brotha out.the car is a 96 the engine is an S15 sr20.
