salty935 »
https://forums.nicoclub.com/salty935-u90444.html
Sun Apr 20, 2008 6:44 pm
The headlight overlays weren't hard to put on at all but it did take time and patience. Here's a quick run down of how I did it and it helps to have an extra pair of hands:
1. Clean the headlight then wet it down with either soapy water or Windex2. Peel the vinyl from the backing and place it on the headlight. 3. Then if you have enough water, you should be able to move and adjust it to exactly where you want it.4. Then I used my driver's license to slowly and carefully push all the water out from under the vinyl. It helps to do it in the sun so you can see all the bubbles and get them out.5. There will be excess vinyl that will wrap around the inside of the headlight. I chose to cut this. I just wrapped it around and whenever the vinyl got dry enough that it wasn't moving around, I used a razor to trim it.6. Then just one final wipe to get all your fingerprints off and Voala!
Easy enough. Took me about 30-45 minutes total for a novice
