Overlays HELP?
2brian0
Car: '08 Altima Coupe 3.5 CVT w/ Tech Package
Had my taillight overlays (bought from Bat) installed by my tint guy. While although they look ok, they aren't right (some creases, had to seam them). Well, Bat is sending me another set and I'm looking for someone to install them right. Anyone know of someone in the Phoenix, AZ area that does this kind of work.....haven't had any luck so far myself.......thanks
djeko5
Car: Nissan, Altima Sedan 07
yo were can i get the pre cut tint film for an 07 altima sedan, i've looked everywere n it seems they have every nissan but the sltima, and i really dont want to get them spray'd.
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
djeko5 wrote:yo were can i get the pre cut tint film for an 07 altima sedan, i've looked everywere n it seems they have every nissan but the sltima, and i really dont want to get them spray'd.
You can get them at Bluebatmobile.net
Brian, Your tint shop shouldn't be cutting them. The need to be warmed up using a heat gun so you can make it pliable. Make sure to check out the directions that came with them.
2brian0
Oh, I know they aren't supposed to be seamed and my tint guy did use a heat gun. However, he was still unable to get the outside corner to shrink up enough. While he has been tinting for 30 years, he has no experience with vinyl and according to Bat that is probably the problem. Still haven't found a local shop to put on a second set for me. Would try it myself but at $40 a pop, these things aren't exactly cheap. Plus, I was able to heat up and fix a few of the problem areas so they don't look so bad now. They just aren't perfect.
SamC.altimacoupeneedshelp
Car: 2008 Nissan altima coupe 2.5s w/ moonroof, convieince package...i need websites that have the things
Where did you get the tail light overlay you have on your car now, in another forum you said that it wasn't from BAT, but 3m? where did you get that?
I'm still trying to learn about where to get what from so if i bother you please tell me
2brian0
If I were you, I would order them on-line from bluebat. He has a good product. I ordered my first set from him and while the install was ok, it wasn't up to my standard. So, I took my car to a local shop and they use two different types of vinyl to do their overlays. I had them put 3M on because I liked it better than the other one they offered (can't remember the name).
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
2brian0 wrote:Oh, I know they aren't supposed to be seamed and my tint guy did use a heat gun. However, he was still unable to get the outside corner to shrink up enough. While he has been tinting for 30 years, he has no experience with vinyl and according to Bat that is probably the problem. Still haven't found a local shop to put on a second set for me. Would try it myself but at $40 a pop, these things aren't exactly cheap. Plus, I was able to heat up and fix a few of the problem areas so they don't look so bad now. They just aren't perfect.
What style headlight overlays are they? Your ride looks sweet.
2brian0
Thanks for the compliments! They were full headlight overlays but I ended up cutting the pattern out myself because I wanted more light since my entire windshield is tinted. Since I did mine, Bat started selling ones almost exactly like mine. He makes good stuff, you should check it out.
skiski329
Car: Nissan Altima Coupe 3.5
I am thinking of getting them my self and putting them on my self. but what is my room for error?
GryStrm
great product but i have no patience...and i just ended up chucking mine after hours of frustration...my tint guy wouldnt touch it....unless ur highly skilled in the manual arts...dont think about it!
Blue Batmobile
Vendor
Car: 1997 NSX
2brian0 wrote:Thanks for the compliments! They were full headlight overlays but I ended up cutting the pattern out myself because I wanted more light since my entire windshield is tinted. Since I did mine, Bat started selling ones almost exactly like mine. He makes good stuff, you should check it out.
Hey Brian, still havent found a shop to install? I'm looking for a good installer to install my Overlays in the Phoenix/Scottsdale area. I have a guy here in San Diego that does virtually all my installs. He's done a ton of Altimas to date. Too bad you werent out here. He'd install them for you. Take care bud
Bat™
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
skiski329 wrote:I am thinking of getting them my self and putting them on my self. but what is my room for error?
I will bet you $100 that if you try these yourself, you will mess them up... the install was too much for most of us do it yourselfers... and when I saw Bat's installer do the install, I was glad I didn't try to tackle it... if a tint guy of 30+ years couldn't do it, what chances do us average D.I.Y.'ers have???
Your best bet will be to wait and find someone to do it, if you can't do that, of course you have to try to tackle it yourself, and if you end up in that boat, please be very patient during the install... it may very well take a beginner 3-4 hours to do the install perfectly...
the biggest hurdle is the wierd curvature of our taillights... the most beautiful aspect of our car becomes both a blessing and the curse when doing this install!!
2brian0
Bat - I actually ended up finding a shop to do my vinyls here in Phoenix (actually Tempe). The shop was called Perfect Symmetry and the installer Jimmy said he knew you from San Diego. He ended up using bulk 3m vinyl for the front, side mirrors, and back. I don't know how people are getting these things on without seaming them. He even had to do the install twice and on the second time had to seam the tail lights. They look extremely clean and you can't even see the seam. For those people out there that do these DYI (at least the tail lights), more power to you!
dj figz
Car: 2011 g25x, 2007 jeep srt-8, 2010 maxima sport w/monitor package,07 altima 2.5s superblack
If anyone from nyc or long island i have a tint guy who installs these and does great work.
i also know of 2 other shops
Savage Auto sports....http://www.savageautosports.com/
unique auto sport.......www.uniqueautosport.com
avenue sound
i got mine done at savageyou can use thier overlays or get bats and bring them thier.
skiski329
but can i remove them later? or when they dry i am fu@#ed?
rjdmmfl1
skiski329 wrote:but can i remove them later? or when they dry i am fu@#ed?
yes, you can remove them later if you don't like them... just ask all the folks that tried to do it themselves and messed up... most of their installs ended ina frustrating rip off of the overlays from their lights... and I'm not clowning them at all, this stuff is hard to do!
2brian0 wrote:I don't know how people are getting these things on without seaming them.
Brian, it can be done without seaming them, but it is EXTREMELY difficult. Bat's installer does the full overlays without seaming them, but he has to seam the GTR-style cutout overlays to make them look good!
skiski329
i rember seeing this in a diff thread but when i searched for it i could not find it. how is payment with Bluebatmobile?
