99_cima wrote:Upon my research through these forums I noticed what someone said about the fan clutch. What was said that if you run the car to op-temp that you wont be able to spin the fan but for a fraction of a rotation.
Correct. When the engine is hot, the fan clutch makes a solid mechanical connection between the water pump pulley and the mechanical fan, so the fan spins at full engine speed.
When the engine is cool, the fan clutch only makes a loose mechanical connection between the pulley and fan, so the fan only spins at a small fraction of engine speed - Essentially, it's just freewheeling.
If the clutch is good, when the engine is hot, you won't be able to spin the fan by hand for more than a fraction of a revolution - The clutch's tight connection to the water pump pulley causes too much drag.
If the clutch is bad, when the engine is hot, the fan will be pretty easy to spin by hand, because the clutch has lost its ability to make a tight mechanical connection to the water pump pulley.
My mechanical fan does not turn off, is it suppose to? It stays on constantly. Did my fan clutch give out?
The fan clutch never completely disconnects the fan from the water pump pulley, so the fan never stops spinning altogether - It just spins more slowly when the engine is cool.
