overheating with new termostat
JPG0511
Car: 1993 240sx fastback
I recently replaced my timing chain componets. While I had the car apart I changed the belts and the termostat. Now I cant get the car to run with the thermostat in without overheating. When I take it out the car does fine. But the heater is really slow to heat up in the morning. I have tried letting it idle with the top off even tried to put some pressure on the radiator with a water hose. I checked the water pump while I had it apart and it is fine. Does anyone know the trick I am missing here?:help :help
mikew04
did you install the thermo correctly? the pin should be at the top, at the 12 oclock position. i messed that one up before and got the same thing you have.
JPG0511
i didnt know it had a certan way to be turned. i know the spring goes in towards the engine but it also has to be rotated a certain way? I will try it tomorrow. thanks!
mikew04
yah theres a pin-like thing at the top, i think its called a jiggle valve or somethin like that.. but yah it has to be at the top. some thermos have "top" imprinted next to it. first time i replaced mine i put it in upside down and experienced the same problems that you have. good luckEDIT: make sure to get all of the air out of the cooling system after you replace it
TachyonS14
Make sure you bleed the air out of the system really good!
yellow_jacket
Car: 95 240sx
Are you opening the bleeder valve when you are filling it with coolant and trying to get the air bled out?
JPG0511
I tried to turn it with the small stem up and it semmed to be working but after about 1mile it started to get hot. the bleeder at the top of the engine where the top radi. hose conects broke off. i have also tested the thormostat on the stove it is working even thought i can really tell at exactly what temp it opens. this is really begining to piss me off. i am going to lett it cool down and make sure the rad. is still full. the thurmosate would not open with the car idleing. kinda cold out
JPG0511
ok i let it cool off opened the radiator up it was full. i started it up and let it run with the cap off for about 15mins no problems. put the cap on and let it idle for another 15mins or so. the i went for a drive no problems. i drove it for an hour or so. i guess it may have had a little air in it but it is all good now. thanks for the help
yellow_jacket
Car: 95 240sx
these cars can be really, really bad to bleed. Especially if the bleeder valve is broken
