Armstec_S13 »
https://forums.nicoclub.com/armstec-s13-u52419.html
Wed Sep 23, 2009 10:34 pm
Ok, I have a 1989 240sx coupe, (SOHC) two weeks ago I was driving to my bros house, I had a problem with my alternator light, I tightend my belt and the light was off and charging fine, one day I forgot my parking lights on, bro jumped me and the light was on again, I disconnected the battery and it ran fine so ALT is good, anyways, I got to my bros house and popped the hood to check the alt ground to see if that was it, I left the car running as I was checking, I looked at the light was still on, fine, I also noticed my gas needle and coolant temp needle, all was good, so I turned the car off to check the tension of the ALT belt, when I turned my car off I heard a loud hissing and smoke coming from the front of the car, I ran to the front of the car and saw coolant spraying out from what seemed to be the radiator cap area so I figured the radiator broke at the filler where the radiator cap connects, I went into the car and turned the key to the acc and noticed the coolant temp needle was to the top. No I didn't turn the car back on.Anyways, I went and looked at the cap and filler and nothing, no crack on the radiator or anything radiator cap looks fine. I let the car cool down I open the cap and refill my coolant but it barely took any coolant to fill up the radiator at all. That was like 2 weeks ago, after that I drove the car a crap load oof times and tonight it did it again, after dropping off my gf, I drove home and sat in front of my house for like 10 to 15 minutes talking to my gf on the phone as the car was still running, I was looking at my temp needle and it was fine (because of lastime), I turned the car off and I hear hissing and see steam, I didn't open the hood cause I knew it was the coolant again and it would burn the crap outta me, I turned the key to the acc and noticed my coolant temp needle is going up and the car isn't even on, WTF???? anyone have any ideas of what it could be? I was told it could be the thermostat, radiator cap, coolant temp sensor, who knows, I know its running fineand the needle reads normal when the car is on, no overheating or anything, as soon as I turn the car off that's when it starts acting up and when I turn the car on to the acc to make the lights on the cluster come on, that's when the needle was moving up to hot. Need any advice or help please.
Modified by Armstec_S13 at 1:44 AM 9/24/2009
