overheating? well almost.
Yuhp
i have finally got my car on the road(91 ka24de) and now i am having some problems. When driving the temp gauge goes all the way to H but not quite overheats. im just worried that if i go somewhere its gonna overheat. it has a alum. radiator with the 2 electric fans. they are wired up by a fan controller with a probe into the fin of the radiator for the temperature. Do you think it will be fine even though the gauge says it is way up there? Most of the time when im driving it will stay about half way or a little less and then there are days where this happeneds, and i am completley shootting blanks.
rushindrifting
Car: 93 240sx , 94 sentra SE-R
Did you find what the problem was? If not check your catalytic converter.
Yuhp
no i didnt find out what it was but i have been driving it when it goes to H i keep driving and it drops just a little bit its running really hot
jdmxbB
Car: Toyota bB
check your radiotor there might be a little
leak some where there. just look around. if not
could be a bad radiotor.
i had the same problem.but i had a tiny whole.
so i just simply replaced it.with another that i
had laying around.
JesterX18
Car: 1991 240sx SE
i would check your thermostat to make sure it sn't stuck mostly closed. Keeping coolant from circulating through your radiator. Also air in your cooling system could also cause an overheating condition.
