huh???ksdmed wrote:Ther is nothing to restrict the flow of water the cool.
I know what the problem is then my heater core line through the intake is not completely tightened down yetSR24DET wrote:Cause there are many other things that attribe to your coolant system.
1. Check for leaks. They lower your booling point.2. Make sure there is no air bubbles in your system.3. Thermistat (which you did)4. Water pump5. And if all that doesnt work Im not sure what to tell you. Some say radiator, but is only bad if it leaks or is plugged.
umm its summer ill put one in when colder weather rolls arond but I dont have any HVAC components anyway so...24j0hn wrote:why do people take out the thermostat, its there for a reason... the thermostat opens and closes with heat so when it closes the cylinders/sleeves heat up the coolant and once the coolant gets hot enough the thermostat opens and puts the hot coolant into the radiator and gets cooled while the coolant that was in the radiator is now around the cylinders... and this goes on and on and on
without the thermostat the temperature cant be controlled and will either be cold(which wastes gas and parts are promised to wear rapidly) or hot( which will make parts fail)...
just go to nissan and order a 240sx oem nissan thermostat which will not fail or be faulty and if it does it has a warranty... its like $25 or get nismo
you could try a pressure test but make sure you dont over pressurize cuz you could blow the headtEknoS13 wrote:Completely agree with hungryjoseph
i don't get it you know where it's leaking and you came to ask for help? if you have a metal hg, it can still leak and blow, it is just more difficult to do it. i've seen it happen twice to apexi hg's and once to a cometic. so i wouldn't rule it out but its definately not the first thing i'd checkZOMG.SR20 wrote:
so leaks
Really? Then why is it that on the race cars I have made, I removed it and they all ran 25% cooler? On the 240sx my heat gague is normally at half way. After removeing it its at 1/4 way? Even when I go to a drift even and beat the living piss out of it, it doesnt go up? And I have a stock rad too.hotrod240sx wrote:put the thermostat back in, with it out the water is spending enough time in the radiator to cool, the water is moving through to fast and will not cool properly.
I was refering to drifting. I will go to a drift day and slide around for 8 hrs and have no over heating problems. Pressure checking the system does sound like a good idea.OutToWinPAHC wrote:Umm the CTS also plays a part in this, Emissions will be horrid without a tstat, but proper warm up of an engine is crucial for normal operations, drag car sis another story, because of the limited times being used and the cool down while waiting with the engine off.
on which post was he flaming??!!?...he was only stating that if everything works properly on your car and you dont run a thermostat....its impossible to overheat....and he is correct.hotrod240sx wrote:well what made me mad was you flame and I wasn't the only 1to make the same statement
