ddgsxr504 »
https://forums.nicoclub.com/ddgsxr504-u24314.html
Tue Feb 15, 2005 10:13 am
SIMPLE FIX CUT AND DRY, REPLACE YOUR RADIATOR CAP, IT IS FAULTY, SAME THING HAPPEN TO ME 3 YEARS AGO, TEMP WOULD BE NORMAL THEN SKYROKET THEN COME BACK DOWN SO ON AND SO ON. AFTER REPLACEING EVERTYHING, THEMOSTAT, RADIATOR HOSES, COMPLETE FLUSH IT TURNED OUT TO BE RAD CAP. IF IT DOESN'T WORK PROPERLY THEN ALL THE COOLED WATER STAYS IN THE RADIATOR AND DOESN'T RETUN TO THE BLOCK. JUST REMEMBER THIS IF YOU EVER HAVE A PROBLEM START EASY, DON'T LET ANYONE ASSUME FOR YOU THAT IT IS THE HEAD GASKET OR WATER PUMP, IF ANY OF THOSE WERE TO GO YOU WILL KNOW!
