ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Sun Jul 11, 2004 1:00 pm
If your temp is shooting up to Hot, then cools down very quickly when you hit the heater, you have air in the system. I know it sounds crazy, but having a little air in there will cause exactly what you're describing. When the car is cool, pop the radiator cap, unscrew the radiator air bleed screw, and start the car. Let it run for a while, and keep topping the radiator off. Once it has run for a while put the screw back in, and the radiator cap back on. Just try this before you go replacing everything in your cooling system.
