Overheating
corey170
Car: 91 240sx 5spd KA24DE h/b (current)
89 240sx A/T 2.4L (old)
Ok I have an 89 240sx (KA24E) and I just changed the water pump. When I start the car from cold, the engine warms up as usual but doesn't stop warming up. Just when the temperature gauge reaches the line second from the top, it steadys off then gradually falls. After a few minutes it will fall back down to regular temp, so it's not like I can't drive. But I'm concerned for my engine. Should I replace my thermostat?
Brent.S14
Car: 1995 Nissan 240sx Coupe-Totaled 1991 Nissan 240sx Hatch-Recent
That's your best option, and probably the cheapest. Just go ahead and replace it and see how your car handles from there.
xX RB Xx
Car: SE3P, FC3S, FC3C.
Probably just air in the system, but if you want you could change the thermostat. It should be quite cheap.
S13k
Car: Mazda miata 99 NB
Nissan 240sx 91 s13
most likely is the thermostat being stuck and unstuck at on point, due the fact that the gauge is move and not constantly going up
corey170
Ok I know there is a thread on here about how to change the thermostat on a ka24de, but in my engine the power steering pump is in the way. Any way around that? I really don't wanna have to take that off and bleed my steering system.
prdquik
Car: S13
did you bleed the system after the water pump install? I think its just that you got air in the cooling system. Jack the front end of the car up, crack the cooling system bleeder screw, And turn the car on and let it run for a while.
corey170
Ya know thats a damn good idea. If it does fix it its such an easy fix. Ill try it tomorrow when I'm off work. For now.. Sleeeeeeep.
prdquik
Car: S13
If you didn't bleed it when you did the water pump, i'm pretty sure thats the problem. Just make sure you get all the bubbles out.
corey170 wrote:Ya know thats a damn good idea. If it does fix it its such an easy fix. Ill try it tomorrow when I'm off work. For now.. Sleeeeeeep.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Bleed the system
corey170
Ok I'm just gonna double check on the bleeding...-Jack up the front end of the car / park on a steep incline-loosen the bleeder screw (or take it right out?) and open the rad cap. -Run the car when its cold-add water to the radiator until water starts coming out of the bleeder-tighten bleeder and close rad cap
is this the way to do it?btw all of your help is much appreciated
corey170
Not tryin to bump the post, just wanted to mention for anyone seeing this thread in the future that bleeding the system fixed the problem. car runs like perfect now
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
90% of overheating in these cars comes from air in the system. glad you're back in business!
