Thanks a lot guys, I will flush and change my coolant as soon as I get a chance. On another note, now having an overheating-phobia of a sort, I was wondering if maybe I should add RedLine Water Wetter to my coolant, as I am planning to turbo the car in the next few months, and since the turbo will be water cooled, it will add an additional strain on the cooling system. Right now I cannot afford an aftermarket radiator, so this seems like a good idea. On the other hand, the website says that it will reduce coolant temperatures by up to 30 degrees, and perhaps it's not the best thing to do int he winter (I know an engine can run too cold). Or does a 30degree drop not mean much to normal running engine temps?
RedLines Website:
http://www.redlineoil.com/redlineoil/wwti.htm
"Red Line WaterWetter® can reduce cooling system temperatures compared to glycol solutions and even plain water. Water has excellent heat transfer properties in its liquid state, but very high surface tension makes it difficult to release water vapor from the metal surface. Under heavy load conditions, much of the heat in the cylinder head is transferred by localized boiling at hot spots, even though the bulk of the cooling solution is below the boiling point. Red Line's unique WaterWetter® reduces the surface tension of water by a factor of two, which means that much smaller vapor bubbles will be formed. Vapor bubbles on the metal surface create an insulating layer which impedes heat transfer. Releasing these vapor bubbles from the metal surface can improve the heat transfer properties in this localized boiling region by as much as 15%..."
And they also mention overboiling, perhaps thisis something I have experienced?:
"Because of the doubling of the ability of the radiator to transfer heat, boilover using Red Line treated water is not a problem as long as the engine is circulating coolant through the head and the fan is circulating air. Sudden shutdown after very hard driving may cause boilover."
If anyone wants to give their opinion on WaterWetter or anything else that is cooling related, please go ahead.
sil80
