overheating?
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
so my car likes to overheat when the A/C is on and im in the stop and go traffic....any ideas?there isnt any antifreeze spewing out or anything....i usually catch it before it gets way up there...but whne i notice it the needle is already 3/4 of the way up the gauge....what do u think it could be?
also what is needed to do the timing belt....i have the new nissan belt i just want to know if theres anything else i need to get while doing it...
brandonjustice93J30
Car: 1993 Infiniti J30
hate to state the obvious....have you checked the level in the radiator?
reason I say is I had problems with my upper and lower thermostat housings, and at first the leaking was just being evaporated and I never seen it dripping until it got really bad.
Modified by brandonjustice93J30 at 1:03 PM 4/24/2008
kbflip02
2006 Infiniti G35x
brandonjustice93J30 wrote:hate to state the obvious....have you checked the level in the radiator?
did a radiator flush when i changed the thermostat...topped off with royal purple antifreeze treatment
yodawill2000
Car: 94 Infiniti J30
Was this an issue before you changed the pulleys ?
j30t_Dan
Car: 2009 Nissan Sentra SE-R
kbflip02
2006 Infiniti G35x
yodawill2000 wrote:Was this an issue before you changed the pulleys ?
yes but not as frequent
yodawill2000
Thats pretty strange ,, Ive driven mine in 105F ambient in stop and go Dallas traffic and never overheated.Maybe the Rad is clogged up ??You might also give this a shot.Loosen the two top rad support brackets and tilt it back a bit.then look down and see if there isnt a boatload of leaves/crap in between the Rad and the condensor ..Mine was a few years back .. made a big differance in temps .
kbflip02
2006 Infiniti G35x
yodawill2000 wrote:Thats pretty strange ,, Ive driven mine in 105F ambient in stop and go Dallas traffic and never overheated.Maybe the Rad is clogged up ??You might also give this a shot.Loosen the two top rad support brackets and tilt it back a bit.then look down and see if there isnt a boatload of leaves/crap in between the Rad and the condensor ..Mine was a few years back .. made a big differance in temps .
what and where is the rad?ive never heard of that before
gr8scott72
Car: 1994 Infiniti J30t
rad = radiator
