cheapscheisst »
https://forums.nicoclub.com/cheapscheisst-u51432.html
Mon Jul 16, 2007 12:01 pm
so i just finished my swap a few days ago, and for some reason im having massive overheating issues. before i removed the thermostat, the car would overheat at idle within five minutes. without the thermostat, it stopped overheating at idle, but the coolant temps were definitely higher than they should be. after a few minutes of VERY VERY conservative driving, my gauge is reading H or higher and im knocking and bucking to no end. my radiator should be fine (it worked perfectly with my ka and i also flow tested it with a garden hose to make sure it wasn't clogged) and i have dual electric fans. the only other possible problem-causer i can think of is the water pump. when i look into the radiator cap hole when i first start up the car, i can see the water flowing, but barely. from what i've heard, it should be flowing pretty quick... this definitely isn't. apparently this is supposed to indicate a bad water pump. however, i replaced mine before the swap with one from enjuku (for the s14 motor, which is supposed to work with an s13 as well) and i tested it for slipping and it seems fine. any ideas?
