veebee »
https://forums.nicoclub.com/veebee-u21980.html
Thu Dec 14, 2006 12:19 pm
My lovely 92 coupe that i recently picked up (hit from the front, look for the thread) had a crack in the radiator, so i went to the junkyard and pulled one from an 89 hatch.
well, after installing it, i drove around. i'm not really sure what to do after installing a new radiator, so yeah. i figured i'd ask now! i drove around, temperature stayed on cold, then shot up to warm, stayed there for about 2-3 minutes then started going higher so i coasted home with the heater on full blast.
i checked the connections and there are no leaks, the reservoir is full, and i filled up the radiator. (however i may not have filled it up enough as i was told to fill it until i can't see the core, which at the time i couldn't, but i probably need to refill it)
please help!
