goldollar »
https://forums.nicoclub.com/goldollar-u5331.html
Wed Mar 02, 2005 5:04 am
IF your getting nothing but cold air when you turn on heat, most likely you have air in the cooling system, or you are low on coolaint. I would check that before anything else but if your car wasnt over-heating previouslyand now it is, most likely you have a bad thermostat.
