VMP wrote:Correct if he is leaking coolent into the combustion chamber.Vegascorbin wrote:It could be head gasket (BIG$$) QUOTE]
if you wanna cancel this out check for white smoke out the tail pipe... and/or oil in the coolant or coolant in the oil. (check dipstick and coolant resevoir)
Remember that in his case he has water on the outside of the block. It is rare but the head gasket could fail and leak to the outside and not into the cylinder.
