overheating!!! still...
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
my car used to overheat a lot before i bought it... i replaced the cylinder head over the past few months, and replaced a bunch of hoses and sensors...well now that its back together it still overheats!!....i replaced the thermostat and that didnt help... i have a hole in my overflow tank if that means anything..
i need help please i dont know what else to check... my radiator is good and there are no leaks from underneath...help please
niemczykj
bump
neverlift
I'll assume this is an s13, you do have the heater on high and the air vent(located next to the cts/temp gauge sensor), if you havent done this your not letting ALL the air out and thats causing your problems. Next could be a bad water pump or faulty thermostat.
niemczykj
with the blowers on high it cools it down....and i just replaced the thermostat.....you think it could be the water pump?
TheOne
Car: 93 240sx FB
did you replace the water pump when ya replaced the cylinder head? if ya didn't, then yes it needs a new pump.
