overheating!!! still...
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
my car used to overheat a lot before i bought it... i replaced the cylinder head over the past few months, and replaced a bunch of hoses and sensors...well now that its back together it still overheats!!....i replaced the thermostat and that didnt help... i have a hole in my overflow tank if that means anything..
i need help please i dont know what else to check... my radiator is good and there are no leaks from underneath...help please
niemczykj
bump
skatermatt180
Car: 1990 240sx fastback
when you get air in the coolent lines you will overheat. Also check your timing, it might be too advanced causing you to run lean and hot. Does the level of your coolent go down when you run the car, can you see it circulating with the cap off while its running. You have air in the system when you get bubbles that pop coolent out of the radiator when the engine is warm.....also make sure you dont smell gas in the coolent, that means you have a bad head gasket.
youngun21a
Car: 240sx 1993 Automatic
Have the same problem,bottom hose cold upper hot,change the thermostat same thing cold and hot hose,so I thought it was the thermostat,hear some termo are defective so I bought two different termo, tryied them both same thing,water pump work,no white smoke,run with out thermo does not overheat till and hour or so in stop and go traffic.and the water level sims low,but don't see water under car or heater core, Can't run it forever with out thermo. I notice something the heater core top hose is hot and the bottom warm,think there is a flow problem??
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
When bleeding your coolant, jack up the front of your car and put a funnel in the radiator. fill it about halfway and make sure that it is the highest point in the cooling system. Run it until there are no more bubbles. KA loves to keep air in the system.
There is actually a FSM procedure as well, but I never have problems doing the way I stated above.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
it could be as simple as your radiator cap.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
As wa-chiss said, it could be the cap. Most people overlook the radiator cap. It is designed to hold a certain amount of pressure in the system before opening to allow coolant to flow into the resevoir tank. Liquid under pressure boils at a higher temperature, so if your cap is not holding the pressuse your coolant will boil over at a lower temperature.
The correct way to fill the ka24de is to open the "air relief valve" (a bolt on the intake manifold just after the upper radiator hose attaches to the manifold), then fill the radiator until coolant comes out the bolt hole.
niemczykj
this topic was originally posted by me, and i have to post my result... after all that went wrong, what seemed like such a huge thing... it WAS just the radiator cap... for 6$ i got a new one and the problem was solved...
leper421
Glad to hear that it is resolved... I think I know how you feel, I've spent hundreds of dollars in the past trying to fix problems with my 240 that wound up being something simple and cheap. After 6 years of maintaining my 240, I have a large stock of spare parts that I will soon be selling since I recently bought a 350z.
niemczykj
congrats on the Z very nice car... this 240 i have is my first car, so itll take me a while to upgrade...
JdrifterCA
Car: 1992 240sx LE
alright.. when i first brouhgt my car... cheap bastard puted 87 gas, and ask i drove it up hill it overheated, but once i got some 91 in it, it ran fine... so yea maybe check timing it might be runing lean... mix water and coolants. water will bring up the boiling points... and drive it at nIHGT!
Blade81
Car: 92 S13 hatch w/redtop SR20DET
i think that it could be a blown head gasket but im not sure.
180fan
Car: 89 fastback
Search how to bleed coolant in the archives. Did you also make sure the thermo had the hole pointing up and the heater on hot and the bleeder hole open?
TIP: have the front lifted or have it at an incline.
EXCURSUS
Car: 91 240sx hatchback
I had the same problem....ended up being the fan clutch...
