I let the car idle for almost an hour bleeding the system with my funnel type bleeder. No problems. The car heats up to the halfway mark, and doesn't barely move more than that. But after a long while, the gauge creeps up to maybe 12:30-1 oclock position. As soon as the motor is revved, the temp goes down to maybe 11 oclock position, but will eventually creep back up. During the idle period...
As I drive around, the temp stays decent, until I come to a stop for a while (think red light). The temp will shoot up to the 1:30-2 oclock or so, not quite to that line before overheating (75%)....but again, if the motor is revved slightly, the temp usually goes down. It NEVER goes past the line before the overheating warning, but this still is way too hot for normal use. I have to fix this so that I know if the car is actually overheating or not.
I have also seen the temp gauge shoot up as soon as the headlights kick on. Not sure how these could be connected, unless the sensor is bad and the extra electrical drain is taking a toll.
So I have a few guesses :
Perhaps my coolant sensor is buggy, and is getting all worked up and going back and forth. I think this is a strong possibility since the temp gauge fluctuates quickly when the motor is revved and as it accelerates and slows, same with the headlights coming on. But since it still "works", my guess is that I am not this lucky
Some sort of blockage in the radiator? Perhaps the accelerating is forcing the water to get past a blockage in the radiator, and so there is a bottleneck in the system? I couldn't really get under there to touch the bottom of the radiator, to see if there was a temp difference, but at least side to side on the top, it is the same temp.
Water pump going out? I have no sounds from the bay, and I have no leaks from a weaping pump, but perhaps the revving is helping the pump cycle the water? I really hope it isn't this serious, but I have no idea when the last time it has been changed.
I am going CRAZY here. I can't even enjoy my car anymore...seems like a problem around every corner, and since this one COULD be serious, I can't risk driving it around town and something serious happening...
Any advice is appreciated. Sorry for the long post
