yes, as i stated eariler. It is in the correct way. i dont think it is actually overheating because the gauge falls quicker than it would take to cool off.angrypenguin182 wrote:might be an obvious statement but it is commonly overlooked, did you put the thermostat in the right way? when i changed mine a while my friend put it in wrong, and thinkin it was the s***ty advanced one, i went to Nissan to get mine, when i took it out i noticed my friend made me spend 20 bucks more than i needed to
I don't know what you guys are having problems with air. I don't do much bleeding and I have never had an overheating problem. even with the block eptied of coolant. I put the stat back in, drain the rad, and fill it up with fresh coolant. I start the car and add more coolant while it's running. I figure, if the rad has enough fluid in it, it will suck enough into the engine forcing the bubbles out the other side and the bubbles release in the rad cap when i have it open (cold of course)GTR PrYdE wrote:In my exp, it's always been a total B to get all the air out of the system.
I've-
Jacked the car up in the front, squeezing the rad hoses
Put a long funnel in the fill hole on rad, put fluid, rev engine/squeeze hoses
Between those 2 things i've gotten all the air out, but it takes time, i've spent over an hour doing this..
Good luck
it sounds like either there's massive blockage since there's pressure in the rad hose and the temp varies greatly from the bottom hose. There's obviously no circulation. As much as it might suck to do. see if you can swap out the rad.240s_are_the_best wrote: when i changed the pump and thermostat i flushed the block, radiator and everything... i just cant seem to figure it out. i took the thermostat out and it works fine. but i am not going to drive it with out a thermostat because it is there for a reason, and i am not burning up my KA before i turbo it I am almost 105% sure it is not the headgasket because there is no water in the oil, oil in the water, bubbles in the radiator, or white smoke out of the exhaust. I went and worked on it for a while until i burnt me hand with hot antifreeze... and got i think all of the air out. i burped the upper radiator hose. took out the ecu temp sensor and bleed it there. loosened the thermostat housing bolts and got alot of air out there. now when i do any of that i only get coolant. it does perfect when it is idling but when i drive it is when the problems begin. i am thinking it is still circulating because the heater is still hot, but if i raise the rpms above 4000 the temp starts to rise. when i get back home the upper radiator hose has so much pressure built up on it that i cant squeeze it and the coolant is boiling. but when i grab the lower radiator hose it is cold. PLEASE HELP!! i have tried everything i can think of.
buy what?? my car?? she is really not for sale now that she is fixed i figured that it may have been mad at me for using mid grade gas instead of 93 octane. when i used 93 and antifreeze instead of tap water wahhlahh she is not mad at me anymorexX RB Xx wrote:ill buy it. how much?
