kouki-gymkhana »
https://forums.nicoclub.com/kouki-gymkhana-u9464.html
Sun Jun 10, 2007 3:24 pm
I was having the same problem a while back. Looks like you forgot to mention if you have any ducting to force the incoming air only through the radiator and not around it. I have the same cooling mods but some well-placed holes in the bumper and ducting above and below the radiator really helped the situation. After all of these mods, I'm seeing ~80-85 C in stop and go without the A/C on on a 94 degree F day. With the A/C on, the temps quickly get as high as 95 C. I think the problems are ultimately due to the following:
1. If you have kept your A/C condenser in place, it really restricts a good bit of the incoming air, especially if you have a big FMIC in front of it.
2. If you have your A/C hooked up and are using it, the condenser gets VERY HOT! and can increase the ambient temp between it and the radiator by more than 70 degrees F. At that point, it doesn't matter how much air your fans can move because they are just moving MORE hot air.
3. The frontal area of the s13 240sx is arguably TOO small to effectively cool the RB25, especially if you haven't added any holes to the bumper. If you need proof, just look at a couple pictures of any R32, R33, or R34 skyline in profile and you will see that their front ends are much taller and punch a much larger hole in the air than the wedge shaped s13.
My advice to you would be to bleed your cooling system very thoroughly, make some underbody ducting, add a bottle of water wetter or another similar product to the coolant, and seriously think about cutting up your front bumper to allow more air to get to the radiator. If all of that doesn't help, you might want to consider a leakdown test to see if you have a blown or leaking headgasket.
Good luck...-KG
