97gesex »
https://forums.nicoclub.com/97gesex-u16625.html
Mon May 24, 2004 7:03 am
when i reinstalled the fan, i just looked at the oxidization on the metal part and you could tell which way it went on. ill double check that though, never hurts.now a possibly dumb question regarding the radiator hose routing:the upper radiator hose goes into the head where the bleeder screw is and the lower one goes into the water neck/thermostat housing correct?i was just pondering what could be wrong and wondered by chance if somehow i mixed the hoses up. i looked at how the hoses were routed on my gsx, and the upper went into the thermostat housing, making me wonder if i ran them wrong on the 240.i also rebled the coolant system by elevating the front of the car, starting it and letting it get up to normal op temp with the heater on full blast. then i took out the bleeder screw and took off the radiator cap. it was blowing bubbles for about 2 minutes or so, and i was just adding coolant until they stopped. unfortunately during this i was bombarded with rain, so i havent had a chance to drive the car since ive done that, but im hoping that was the correct way to do it.
thanks a lot for the suggestions so far, keep them coming.
