In that case, your mechanic should be troubleshooting itaquariustiger wrote:ok then! ill be sure to check for trap air as u guys are stating
...p.s. I wasn't the one who replace my pump & thermostat, so i'm thinking it was my mechanic.
hey ill be doing that after i give it good flush; one thing the radiator plug is not like the 89sxi'm having trouble getting that sucker free; i don't want to break it...any suggestions. is this plug replaceable???Rucca wrote:Did you bleed the system thoroughly?
It is possible to install a thermostat backwards - which will cause overheating and can cause the overflow tank to fill. Basically the overflow tank will fill up if the coolant boils and expands - which is commonly caused by air in the system not allowing the coolant to build sufficient pressure (air can be compressed, fluid cannot - pressure lowers boiling point).
You can try replacing the radiator cap if that doesn't work.
I suppose if your problem persists after thorough bleeding, you should check your system for leaks thoroughly and perform a pressure test.
on the 89 model i believe theres just two bleeder valves; one the driver side on the block & one on top of the engine next to the coolant temperature sensor.is this correct for the 91 model?pwrofdrm wrote:Sounds like air in the system, make sure all bleeder valves are closed, run the car with the cap open and heat on, see if any air bubbles up. You might try getting a new radiator cap while you're at it, because over heating or not, you should be releasing some pressure when you take the rad cap off a hot car.
