overheating probs
twoclark426
Car: 240sx
92 vert w/RB20 DET and racing intercooler. stock radiator. Overheats after like 20 miles. All the coolant will burn off. Any ideas? Radiator? Thermostat?
biggie
Couple others: Air bubbles, blown headgasket.
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
All the coolant burns off? You sure it's not all leaking out?
twoclark426
Car: 240sx
gaskets fine. new ones put in w/the motor 9 months ago. Air bubbles where?
twoclark426
Car: 240sx
Positive. I never see it on the ground at least and you can see the boiling in the reservoir. The only place it comes out is the relief, but that's b/c it's boiling so violently by th time I stop
biggie
twoclark426 wrote:gaskets fine. new ones put in w/the motor 9 months ago. Air bubbles where?
Air bubbles in the coolant system, not allowing coolant to flow through the engine properly. If you are just throwing coolant into the rad without any attempt at bleeding the system of air, then I'd say that's the issue.
Clogged rad could be it though if not the air bubbles.
94_240sx
Car: 94_240SX
RB????It's about time Eikon shows and posts his infamous water pump. Anyway, water pump is good? Specifically, blades.
Eikon
Car: 71 240z, 93 Supra TT
I am way too well acquainted with overheating problems on my RB20. what a saga!!!
Is your RB20 stock still?
Have you bled the system properly using the bleeder on top of the intake plenum?
Did you have the water pump replaced before install?
Do you get heat inside the cabin for prolonged time?
I can def. help you through this as I've gone through the whole deal myself.
Do you have AIM? Mine is xx eikon xxCall me if you want.. 920 - 819 - 2271
srphoenix
Car: 08 Mitsu Evolution X
Seth will know more then me on this issue, but I know my SR kept overheating due to a broken leaking radiator.
hopefully you get it all worked out
94_240sx
Car: 94_240SX
A local guy had overheating problem for months. He replaced thermostats several times and bled real good too. Checked radiator and it seemed like working.
Problem was stock raditor was partially clogged, so coolant was flowing well enough. He bought the Mishimoto radiator and problem fixed. Coolant system is pretty simple, so if you try 3 or 4 things and it should get fixed.
twoclark426
Car: 240sx
yes still stock, new water pump w/install and I have a spare. I flushed the radiator but no I haven't tried bleeding it yet.It does get hot in the cabin, but when it starts to heat up I turn the heat on until I can stop somewhere.Don't have aim but I'll try bleeding it and let ya'll know. Preciate the help
twoclark426
Car: 240sx
Still no luck. Can anyone suggest a good radiator for the RB20. I'm noticing there's no specific radiators like there are for the SR20.
Bryant0086
Car: 1989 Nissan pickup 2004 Nissan Quest SE 1992 240SX vert
If you haven't replaced it yet, definitely replace the thermostat. It is cheap and is very common that it goes bad. It can "stick" partially open as well which would allow some water to go through to supply enough water to the heater core etc.
Bryant
twoclark426 wrote:Still no luck. Can anyone suggest a good radiator for the RB20. I'm noticing there's no specific radiators like there are for the SR20.
Eikon
Koyo upgrade S13 KA radiator should work fine for you. The RB really needs the extra width over the stock ones. It's a hot running engine.
The aluminum ones are even better if you want to spend the extra money. http://cgi.ebay.com/ebaymotors...ZWDVW
The stock KA has both ports on the passenger side like you need.
twoclark426
Car: 240sx
thans for the link. That's not too ba dfor a koyo. The mishimoto is cheaper though. Any major diff?
twoclark426
Car: 240sx
How's the mishimoto workin for that guy? I saw that that one is for MT only and I haven't done the conversion yet. Would it still work with auto?
