OVERHEATING problems...
K240
Car: 1993 240sx
PLEASE READ THE ENTIRE POST! I am so pissed...my 240 has been overheating....I have been noticing the signs that my car has had a blown headgasket...I called the shop where i had my car done, to see if it was done. They said it is donje, but is still overheating.....I dont know what else it could be, i have all new cooloing system...what else could it be? here is what i have done-new Headgasket/resurfaced head/valves -new radiator, KOYO but not aluminum-new water pump-new thermostat-twin flex-a-lite fans wired up to the fuel pump-new radiator hoses-new radiator cap-flushed and bleeded system-I also have the stock mechanichal fan being used, w/ the twin fans....
edit- PLEASE HELP!!!
K240
Car: 1993 240sx
oh btw i have a 93 240sx
s13sr20chris
try a new thermal transmitter. its the little one wire sending unit next to the regular coolant temp sensor. i think its like $10 from the dealer. try to get it from one of our sponsors like pinnacle nissan. its a cheap part and i have seen them read hot when the motor is not hot.
K240
Car: 1993 240sx
ive replaced that too. =[
s13sr20chris
have you verified that it is in fact overheating by popping the hood and checking?
K240
Car: 1993 240sx
yes.
K240
Car: 1993 240sx
any one? NISTECH?
K240
Car: 1993 240sx
My mechanic is stumped too...=[
s13sr20chris
well, if it is indeed overheating and all the above stuff is fixed...i dont know. you have kinda done everything. are they oem parts? i had a freind who got a water pump with the impeller on backwards. i have also seen many name brand(big names too) aftermarket thermostats that are no good right out of the box.
K240
Car: 1993 240sx
the thermostat is OEM. The water pump is from autozone...My timing has been advanced, could that have anything to do w/ it?
K240
Car: 1993 240sx
any one?
psychic_mechanic
Car: the world's ugliest civic
Random ideas to all cars, may not apply to 240's:
Fan shrouds/airflow through rad, not aroundare fans working together or fighting each other?clogged cooling passages in head/blockverify gauge is accurateradiator capset timing to stock, just to checkchemical flush cooling systemwater wetterrunning lean?
K240
Car: 1993 240sx
it was the radiator, it was a 1 row, instead of a 2 row...
