180fan wrote:you check for bubbles via that burping hole on your coolant elbow? there's a 10mm bolt that's plugging the hole up. Also did you boil the thermo first to make sure it's working ok? When it was bled, was it bled with the heater control set to hot and then the system properly bled? Is your headgasket installed properly? those are all the normal run of the mill questions that could be the cause of your problem.
180fan wrote:well have you touched the lower radiator hose? if it's cold it's the thermo. You may want to check that. Also how is your turbo cooled? Your turbo may be running a bit too hot for a single row or the single row you've got may not really be able to keep up with the heat pumped out by your system. Fan's aren't gonna do too much on the highway, air flow's got more to do with that and the heat capacity of the coolant and the ability to dump it from the radiator. Sorry to say it may be your radiator just may not have what it takes to keep up.
lol, sorry, i wasnt getting confused with another overheating post i was helping someone on.K240 wrote:boost....i have a stock KA...
180fan wrote:lol oops sorry dude i thought you had a turbo cuz of some other guys were talkin bout boost so I assumed I missed that in your post about having a turbo. lol.
Yeah if your lower rad hose is still cold while the upper one is hot, your thermo's junk and not working. Replace and you should be better.
