Overheating problems.
Garrison
Car: 1995 Nissan 240sx
I have a 1995 240sx with a stock ka24de. I've recently had trouble with the engine overheating and had the fan clutch changed. It worked the whole way home and then the next day started overheating again...It dosen't do it all the time...it's very random.I was wondering if anyone could tell me of any other causes for this.I have no coolant leaks and my radiator is fairly new.'thanks.
driftedsilvia
Car: 93 Fastback
thermostat... if you have obd1 system you can just take it of if its obd2 just replace it. Thats the chapest place to start a Tstat runs you like 5$ and it fairly simple to install....
Garrison
I haven't thought about that. I'll give it a try...any temp. I should do with? Or should I just go with the oem temp.?
Could it possibly be a relay?I knoticed in my repair manual that there are two...this is so frustrating!
thanks.
driftedsilvia
Car: 93 Fastback
those relays are for your A/C condenser fan.. wont afect anithing uless ac is on...if your car is obd1 just take of the Tstat. if its obd2 just replace it witha lower temp one you only get two choices at your part store. If you are still overheating after that........Your radiator might look new but you cant really tell whats going on inside untill you gett it checked just take it to a radiator shop. here the charge like $45 to clean it..
Garrison
Thanks alot.I have the day off tommorow so I'll try to get the new thermostat installed. Hopefully that solves my problem.
It gets hot after about 15 to 20 minutes of driving...then it looks like the thermostat opens up and it starts to cool...then gets hot again.
Should I go for the lower temp. one, or will that affect performance?
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
yeah i have a ka24e and i just had the same problem... i started with the fan clutch and then moved to the thermostate,coolant temp sensor, water pump, and after i had eventually changed the whole coolant system besides one thing...it still overheated. it turned out my radiater which was 4 months old had some how become clogged...got it rodded and it hasnt overheated since. hope this helps i know how fustrating it is being hot all the time.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Garrison wrote:Should I go for the lower temp. one, or will that affect performance?
Get an OEM thermostat from a Nissan dealer. Stay away from those cheap aftermarket thermostats; they may times cause more problems.
If you try to use a lower temperature unit, the ECU will sense this and provide a rich mixture; this will make the motor run poor and affect the MPG.
Garrison
I finally got the damn thermostat installed. Now it's running great. Next project is to get the damn timing guides out...I hate the rattling.
